Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing. remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing. remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing.
  • remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing.
Hebe die Antenne hoch und schiebe sie aus dem Gerät heraus. Die Antennenkabel können unter dem Kühlkörper durch eine Öffnung herausrutschen (mit einem roten Pfeil markiert).
