Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Peel up the six cable loops securing the antenna cables to the upper case. Gently pull the cable loops slightly out of the channel cut into the upper case one at a time. Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Peel up the six cable loops securing the antenna cables to the upper case.
  • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
  • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Repeat this for all five retaining loops.
Hier Übersetzung einfügen
