Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Remove the 2 Phillips head screws securing hard drive to case. Use the same screw driver bit as before. Pull the plastic tab connected to the hard drive outward in the left hand direction to remove hard drive from case. Place the hard drive off to the side.
  • Remove the 2 Phillips head screws securing hard drive to case. Use the same screw driver bit as before.
  • Pull the plastic tab connected to the hard drive outward in the left hand direction to remove hard drive from case. Place the hard drive off to the side.
  • When putting the hard drive back slide it in to the space so that the screw holes line up and press down until there is a snug fit.
Hier Übersetzung einfügen
