Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
Optional: Disconnect the Battery
  • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
  • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
  • Turn the computer back over and open the display to the point where you can press the power button.
  • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
Hier Übersetzung einfügen
