Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
7. Schritt
Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop. The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
  • Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
  • The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
  • Lightly pull the ribbon cable away from the connector.
Hier Übersetzung einfügen
