Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it. Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
  • Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
  • Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
Hier Übersetzung einfügen
