Zum Hauptinhalt wechseln
Englisch
Deutsch
10. Schritt
Kein Bild
Top Case
  • Rotate the feet to the up position.
  • Using a T-8 torx driver, remove the screw located under each foot.
  • Remove the four screws at the front edge of the bottom case
  • Remove the remaining screw on the inside top edge of the case.
  • Carefully lift and rotate the top case toward you and disconnect the track pad cable from the motherboard.
  • Remove the interconnect to logic board cable from the opening for the right clutch.
  • Remove the top case.
Hier Übersetzung einfügen
