Englisch
Deutsch
10. Schritt
Use the 2.0 mm flathead to flip up the brown tab on the motherboard and carefully unseat the ribbon cable Insert the tip of the 2.0 mm flathead screwdriver into the hole on the daughter board, then apply upward force to remove the daughter board from the main case
  • Use the 2.0 mm flathead to flip up the brown tab on the motherboard and carefully unseat the ribbon cable
  • Insert the tip of the 2.0 mm flathead screwdriver into the hole on the daughter board, then apply upward force to remove the daughter board from the main case
Hier Übersetzung einfügen
