Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing. Attached to the wifi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the wifi card. Once the wire is removed, set it aside so it does not get damaged.
  • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
  • Attached to the wifi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the wifi card.
  • Once the wire is removed, set it aside so it does not get damaged.
Hier Übersetzung einfügen
