Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components. Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
  • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
  • Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
  • Remove the rubber feet on the bottom of the laptop closest to the screen hinge to gain access to the remaining 2 5mm screws. Keep these screws separate from the first 11.
Hier Übersetzung einfügen
