Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass. Insert the tip of a spudger underneath the black rubber gasket at the bottom right corner of the display assembly.
  • It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass.
  • Insert the tip of a spudger underneath the black rubber gasket at the bottom right corner of the display assembly.
  • Gently pry the wide edge of the gasket up from the back case.
Hier Übersetzung einfügen
