Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone). Pry the bottom shield to separate it from the phone. Once it is loose you should be able to remove it with your hand.
  • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
  • Pry the bottom shield to separate it from the phone.
  • Once it is loose you should be able to remove it with your hand.
Hier Übersetzung einfügen
