Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector. CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
Popping up the Memory Module
  • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
  • CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
  • Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
Hier Übersetzung einfügen
