Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 5
Take out the center screw,  near the blower fan, and the screw in the small SD card reader assembly. Then using tweezers or a spudger, carefully remove the SD card reader and detach the flex cable from the board; you can do this by carefully sliding a spudger under the area covered by the foam and gently prying up. it comes off fairly easily. Take out the center screw,  near the blower fan, and the screw in the small SD card reader assembly. Then using tweezers or a spudger, carefully remove the SD card reader and detach the flex cable from the board; you can do this by carefully sliding a spudger under the area covered by the foam and gently prying up. it comes off fairly easily. Take out the center screw,  near the blower fan, and the screw in the small SD card reader assembly. Then using tweezers or a spudger, carefully remove the SD card reader and detach the flex cable from the board; you can do this by carefully sliding a spudger under the area covered by the foam and gently prying up. it comes off fairly easily.
Complete Metal Plate Removal
  • Take out the center screw, near the blower fan, and the screw in the small SD card reader assembly. Then using tweezers or a spudger, carefully remove the SD card reader and detach the flex cable from the board; you can do this by carefully sliding a spudger under the area covered by the foam and gently prying up. it comes off fairly easily.
Drehe die Schraube in der Mitte nahe am Lüfter heraus. Drehe dann die Schraube an der kleinen SD Kartenleseeinheit heraus. Entferne den SD Kartenleser vorsichtig mit einer Pinzette und löse das Flexkabel von der Platine ab. Schiebe dazu vorsichtig den Spudger unter den von Schaumstoff bedeckten Teil. Heble hoch und es kommt leicht heraus.
