Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
Caution: Lithium-ion batteries are fragile and can ignite if punctured or bent. Be careful when prying and do not use metal tools. Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out. Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out.
Carefully Remove the Battery
  • Caution: Lithium-ion batteries are fragile and can ignite if punctured or bent. Be careful when prying and do not use metal tools.
  • Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out.
Benutze sehr vorsichtig einen Spatel und trenne die Verklebung des Akkus auf, indem du ihn an verschiedenen Stellen in einem flachen Winkel einschiebst. Bei mir ging es gut, indem ich erst auf beiden Seiten und dann die Mitte entlang ging. Heble nicht damit nach oben, es genügt, den Kleber aufzutrennen.
[title] Carefully Remove the Battery
[* icon_caution] '''Caution: '''Lithium-ion batteries are fragile and can ignite if punctured or bent. Be careful when prying and do not use metal tools.
[* black] Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out.
