Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
Gently flip the tan cable lock back to release the ribbon cable from the lower PCB Board. Using a plastic or metal spudger gently pull the ribbon cable from its socket. Remove the 3mm screw from the PCB Board using Phillips#000 Screwdriver.
  • Gently flip the tan cable lock back to release the ribbon cable from the lower PCB Board.
  • Using a plastic or metal spudger gently pull the ribbon cable from its socket.
  • Remove the 3mm screw from the PCB Board using Phillips#000 Screwdriver.
Hier Übersetzung einfügen
