Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides. Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver. A magnetic screwdriver will help you remove the screws from their slots.
  • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
  • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
Hier Übersetzung einfügen
