Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen. Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins. Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
  • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
Hier Übersetzung einfügen
