Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 9
Once you've done that you want to go around and unscrew the following bolts to remove the main lid on the console. After you've removed the lid right under where the card is placed should be the connector for the card. Now hold the black wifi board connector in place with the lid and screw it into the metal lid holding it into place.
Wifi card reassembly
  • Once you've done that you want to go around and unscrew the following bolts to remove the main lid on the console.
  • After you've removed the lid right under where the card is placed should be the connector for the card.
  • Now hold the black wifi board connector in place with the lid and screw it into the metal lid holding it into place.
  • After that go through and screw down the metal lid and tighten all the bolts snug.
Löse danach alle Schrauben, welche den großen Deckel in der Konsole festhalten.
Entferne den Deckel. Dort wo sich die Karte befunden hat findest du den Anschluss der Karte.
Halte den schwarzen WiFi Anschluss an Ort und Stelle auf dem Deckel und schraube ihn im Metalldeckel fest.
Danach kannst du den Deckel wieder festschrauben.
