Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use a heat gun to heat the edges of the screen, loosening the adhesive underneath. Run a jimmy or similarly thin object around the edge of the screen.
  • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
  • Run a jimmy or similarly thin object around the edge of the screen.
  • Using a suction cup, lift up on the screen to separate it from the adhesive.
  • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
Hier Übersetzung einfügen
