Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
5. Schritt
In the following steps, you will use a heat gun to soften the adhesive securing the outer silver border around the underside of the front panel to the display.
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer silver border around the underside of the front panel to the display.
  • With the heat gun set to low, start by heating the metal bezel surrounding the LCD.
  • When using the heat gun, the goal is to soften a layer of adhesive holding the bezel to the display assembly. Be very careful not to overheat the LCD, as it could cause permanent damage.
Hier Übersetzung einfügen
