Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Step 1
On the bottom half of the device's head, locate the two screws on each side of the speaker. Using the Phillips #1 driver remove the two 7mm screws. Remove the black brace holding the speaker by gently pulling on it. The speaker will likely fall out after lifting the black brace. Remove the black brace holding the speaker by gently pulling on it. The speaker will likely fall out after lifting the black brace.
  • On the bottom half of the device's head, locate the two screws on each side of the speaker. Using the Phillips #1 driver remove the two 7mm screws.
  • Remove the black brace holding the speaker by gently pulling on it. The speaker will likely fall out after lifting the black brace.
Hier Übersetzung einfügen
