Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2 übersetzen
Step 2
Remove the speaker and place down on a flat surface. The speaker will remain attached by two white wires. Using the soldering iron,  heat the soldering points and carefully pull the two wires away from the speaker to completely detach. The soldering iron is very hot, so take caution not to touch it directly in order to avoid any burns to the body.
  • Remove the speaker and place down on a flat surface. The speaker will remain attached by two white wires.
  • Using the soldering iron, heat the soldering points and carefully pull the two wires away from the speaker to completely detach.
  • The soldering iron is very hot, so take caution not to touch it directly in order to avoid any burns to the body.
Hier Übersetzung einfügen
