Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Turn the computer over and open the display as far as possible. Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board. Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
  • Turn the computer over and open the display as far as possible.
  • Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
  • Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
  • Lift the palm rest away from the display assembly.
Hier Übersetzung einfügen
