Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
Using the Torx T8 screwdriver, remove the 13 Torx 6 millimeter screws on the bottom frame of the laptop.
  • Using the Torx T8 screwdriver, remove the 13 Torx 6 millimeter screws on the bottom frame of the laptop.
  • Using the Phillips P0 screwdriver, remove the 2 Phillips 6 millimeter screws on the bottom frame of the laptop.
  • The 2 Phillips 6 millimeter screws can be identified by the small keyboard logo nearby.
  • Remove the 2 Phillips 3 millimeter screws from the edge of the frame where the optical drive was previously located.
  • Remove the 5 Phillips 3 millimeter screws from the area where the battery was previously located.
  • The Torx screwdriver is the screwdriver with a six-pointed star shaped tip. T8 refers to the name/size of this particular Torx head screwdriver.
  • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
Hier Übersetzung einfügen
