Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
8. Schritt
Using a plastic opening tool, slowly and carefully detach the top cover from the bottom frame. Do not do this step too fast or forcefully as there is a hidden cable connected between the two frames.
  • Using a plastic opening tool, slowly and carefully detach the top cover from the bottom frame.
  • Do not do this step too fast or forcefully as there is a hidden cable connected between the two frames.
  • Make sure all of the screws mentioned in the previous steps have been removed. If some screws remain, the frames will not separate.
Hier Übersetzung einfügen
