Englisch
Deutsch
3. Schritt
Slide the spudger down the left side of the cover to loosen the clips. After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands. When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  • Slide the spudger down the left side of the cover to loosen the clips.
  • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
  • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
Hier Übersetzung einfügen
