Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Flip over the laptop and position it with the battery being furthest away from you. Remove the four screws on the edges of the T-Shaped plate. Remove the T-Shaped plate from the back of the computer.  It should come off easily if all four aforementioned screws are removed.
  • Flip over the laptop and position it with the battery being furthest away from you.
  • Remove the four screws on the edges of the T-Shaped plate.
  • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
  • Screw length 6.35 mm, head 3.175 mm
Hier Übersetzung einfügen
