Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
2. Schritt
Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame. Remove the antenna assembly. Remove the antenna assembly.
  • Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame.
  • Remove the antenna assembly.
Hier Übersetzung einfügen
[* black] Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame.
[* black] Remove the antenna assembly.
