Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away. Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information. Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
  • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
  • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
  • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
  • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Hier Übersetzung einfügen
