Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a  screwdriver. Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver. These screws can also be Torx on some models.
  • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
  • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
  • These screws can also be Torx on some models.
  • Pull off the rear case.
Hier Übersetzung einfügen
