Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Hold the joystick down with your left thumb to make space for the plastic opening tool. Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel. Slide the plastic opening tool around the perimeter until you can lift the front panel.
  • Hold the joystick down with your left thumb to make space for the plastic opening tool.
  • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
  • Slide the plastic opening tool around the perimeter until you can lift the front panel.
  • You may hear a popping noise when you pry off the front panel.
Hier Übersetzung einfügen
