Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel. Push down on the end of the plastic opening tool closest to you to lift the panel up.
  • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
  • Push down on the end of the plastic opening tool closest to you to lift the panel up.
  • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
Hier Übersetzung einfügen
