Englisch
Deutsch
8. Schritt
ONLY FOLLOW THIS STEP AND THE NEXT IF YOU ARE REPLACING THE ENTIRE WIRE HARNESS IF NOT THEN SKIP THIS AND STEP 9. When replacing the wire harness you need to disconnect the upper portion of the harness from the mechanism and then locate the quick disconnect . Quick disconnect
Wire harness
  • ONLY FOLLOW THIS STEP AND THE NEXT IF YOU ARE REPLACING THE ENTIRE WIRE HARNESS IF NOT THEN SKIP THIS AND STEP 9.
  • When replacing the wire harness you need to disconnect the upper portion of the harness from the mechanism and then locate the quick disconnect .
  • Quick disconnect
Hier Übersetzung einfügen
