Zum Hauptinhalt wechseln
Englisch
Deutsch
3. Schritt
Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case. Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case. Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case.
  • Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case.
Schiebe von links beginnend ein Plektrum unter das Flachbandkabel zur Ladeeinheit, um es so vom Gehäuse abzulösen.
