Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid. Pull off the Google Home’s magnetically attached base and set it aside. Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
  • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
  • Pull off the Google Home’s magnetically attached base and set it aside.
  • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
  • After all four screws are out, pop the lid off the device to open the capsule.
Hier Übersetzung einfügen
