Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone. Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
  • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
Hier Übersetzung einfügen
