Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
At the top end, gently insert pointed end of spudger underneath the motherboard. Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard. Remove the motherboard from the device.
  • At the top end, gently insert pointed end of spudger underneath the motherboard.
  • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
  • Remove the motherboard from the device.
Hier Übersetzung einfügen
