Zum Hauptinhalt wechseln
Englisch
Deutsch
20. Schritt
Now you can remove the LCD panel, along with the hinges. Note: Lift from the top or left side first. As seen in the second image here, your wifi wire runs up the side of the back panel. Unless you want to put it back into those little grooves, I suggest removing the LCD, and laying it on its face WHILE the wifi line is still intact with the back plastic.
  • Now you can remove the LCD panel, along with the hinges.
  • Note: Lift from the top or left side first. As seen in the second image here, your wifi wire runs up the side of the back panel. Unless you want to put it back into those little grooves, I suggest removing the LCD, and laying it on its face WHILE the wifi line is still intact with the back plastic.
Hier Übersetzung einfügen
