Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case. Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case. Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case.
  • Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case.
Heble die Wi-Fi Antenne mit dem flachen Ende eines Spudgers vom Rückgehäuse hoch, beginnend unter der Kabelverbindung.
