Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Locate the two 2.5mm screws at the bottom two corners of the inside of the phone. These screws will not be visible or accessible unless the 2 sides of the phone are at approximately 90 degrees relative to each other.
  • Locate the two 2.5mm screws at the bottom two corners of the inside of the phone.
  • These screws will not be visible or accessible unless the 2 sides of the phone are at approximately 90 degrees relative to each other.
  • Use a #00 Phillips screwdriver to remove both 2.5mm screws.
Hier Übersetzung einfügen
