Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the screws on the back of the controller with the Phillips #000 screwdriver. Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside. Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
  • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
  • Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
  • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
  • Place screws on magnetic project mat to avoid losing any screws.
Hier Übersetzung einfügen
