Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using either the spudger, tweezers or your fingers, remove the wire connectors from the WiFi card by pulling up. The wire connectors should disconnect from the WiFi card with minimal force; Refrain from pulling too hard, as you might damage the WiFi card further. The wire connectors should disconnect from the WiFi card with minimal force; Refrain from pulling too hard, as you might damage the WiFi card further.
  • Using either the spudger, tweezers or your fingers, remove the wire connectors from the WiFi card by pulling up.
  • The wire connectors should disconnect from the WiFi card with minimal force; Refrain from pulling too hard, as you might damage the WiFi card further.
Ziehe die Stecker an der Wi-Fi Karte mit einem Spudger, den Fingern oder einer Pinzette hoch.
Der Stecker sollte sich leicht von der Karte lösen lassen. Sei trotzdem vorsichtig und ziehe nicht zu kräftig, das könnte die Wi-Fi Karte weiter beschädigen.
[* red] Using either the spludgerspudger, tweezers or your fingers, remove the wire connectors from the WiFi card by pulling up.
[* icon_note] The wire connectors should disconnect from the WiFi card with minimal force; Refrain from pulling too hard, as you might damage the WiFi card further.
