Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
8. Schritt
Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you. Remove one 6 mm screw with a Phillips #2 screwdriver. Spin the device so the opposite side is facing you.
  • Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you.
  • Remove one 6 mm screw with a Phillips #2 screwdriver.
  • Spin the device so the opposite side is facing you.
  • Remove the two 6 mm screws with a Phillips #2 screwdriver.
Hier Übersetzung einfügen
