Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device. If you are having trouble using the blue plastic opening tools, try using the black spudger instead. If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
  • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
Hier Übersetzung einfügen
