Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 12
If using liquid adhesive remover, apply another 1 milliliter or so under each of the final two, middle cells. It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work. Allow 2-3 minutes for the adhesive remover to penetrate before you continue.
  • If using liquid adhesive remover, apply another 1 milliliter or so under each of the final two, middle cells.
  • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
  • Allow 2-3 minutes for the adhesive remover to penetrate before you continue.
  • Gently folding the right-most battery cells out of the way, insert a plastic card under the right center cell.
  • Push the card in about half of its length to cut the adhesive holding the battery cell to the case.
  • Be sure to avoid the trackpad control board. Aim the card up toward the logic board, where the adhesive is.
  • Leave the card in place to keep the adhesive from re-sealing.
Hier Übersetzung einfügen
