Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
7. Schritt
The casing should be easily removed by prying and lifting it off. If the casing gets caught on the back panel of plugs, use the metal spudger to lift the casing away from the panel, working all the way around. Pay special attention to the bottom, where it may be stuck with glue.
  • The casing should be easily removed by prying and lifting it off.
  • If the casing gets caught on the back panel of plugs, use the metal spudger to lift the casing away from the panel, working all the way around. Pay special attention to the bottom, where it may be stuck with glue.
Hier Übersetzung einfügen
