Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
  • Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
  • Use the plastic opening tool to gently pry the wires loose from the power switch.
  • The wires should pop easily out from the power switch.
Hier Übersetzung einfügen
