Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Remove the two remaining ribbon cables. Remove the screws holding in the protective cover underneath the keyboard. Pop the cover off, starting with where you took out the optical drive
  • Remove the two remaining ribbon cables.
  • Remove the screws holding in the protective cover underneath the keyboard.
  • Pop the cover off, starting with where you took out the optical drive
  • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
Hier Übersetzung einfügen
