Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
31. Schritt
Remove the battery isolation pick. Insert a plastic card underneath the logic board at the battery connector. As you push through the adhesive at the outer edge of the logic board, be careful not to damage the upper button assembly ribbon cable that you disconnected in Step 60. Position the card exactly as shown.
  • Remove the battery isolation pick.
  • Insert a plastic card underneath the logic board at the battery connector.
  • As you push through the adhesive at the outer edge of the logic board, be careful not to damage the upper button assembly ribbon cable that you disconnected in Step 60. Position the card exactly as shown.
  • Slide the card all the way underneath the logic board, separating the adhesive along the outer edge.
Hier Übersetzung einfügen
